1 - 16 of 16 Posts
I keep reading that you have to remove the speed sensor. I CANNOT GET THAT THING OUT!! Is there another place to fill it with fluid? I heard there is another plug that I believe is a 1/2" socket? Is this true? If so does anyone have a picture of its location? Thanks a ton!
Destroyer of worlds.
alright, im not sure if there is a fill plug on the ga16 tranny or not, but there is one on the sr20...so im assuming there is one.
if it's there it'll be on the front of the transmission, about halfway(or a third, cant quite remember) up from the bottom. it will look exactly like the drain plug.
yea dude tranny drain/fill plugs are weird i didnt know what to look for at first even readin the book i was confused, but anyway. the drain plug is about the size of a half dollor and u stick a half inch DRIVE wratchet right to the "bolt" and the fill plug is the same thing but smaller and u use a 3/8 DRIVE wratchet. the fill plug should be in front of the tranny about 3 inches up from the bottom and the drain i think is on the back closer to the bottom, not positive on that
Are you sure its the same for the 1.6 transmissions? I see that you have an sr20de equipped car. I had the transmission out and did not see such a plug. Does anyone have a reference picture of its location?
there is fill plug, i think it's on the back upper side of the tranny, it's been about 2 years since i've had my b13 so im not 100% sure, you may have to reove the intake box and hose to get to it
It looks like its on the front side towards the radiator doesnt it? The drain is on the bottom I think
it could be on the front i'll check my repair book when i get home later, but it there some place.
Boxed Fox
That's right. the fill plug is in the front, right in front of the radiator. It's very easy if you jack the front end of the car up and go in from underneath. Remember to put a catch pan underneath, or you're going to have a nice transmission oil spot on your driveway.
Your electrical friend
I've had both trannies and they both have fill plugs on the side facing the radiator. I'd also use synthetic fluid. You don't have to go all out and get Motul or Redline, but considering how often it gets changed out, it's not a bad investment to put in the best.
6-1/8 pints, so buy a gallon and you'll have most of 1 quart left.
yes, use the MT-90 GL4 only fluid. if you use GL-5 you will wear the syncros fast. use GL-4. redline
The plug is in the front. I always get new plugs because the rachet chews up the plug good. The plug is metric, but there is no metric drive that I know about. I would get the 2 plugs each time you change it out. The drive is really sloppy in the plugs.
Chris 92 classic
1 - 16 of 16 Posts
