1 - 20 of 21 Posts
Boxed Fox
Red Nissan said:
Does anybody know how good ceramic brakes are and are they easy to put :rolleyes: on? I am going to put pads on my hardbody later on this year when it starts to warm up outside.
By "ceramic", do you mean ceramic based brake pads or ceramic-on-ceramic brake systems (ceramic rotors too)?
Boxed Fox
Red Nissan said:
Ceramic based pads not the calibers :cool:
Ok. In that case, the ceramic pads you're talking about are not that different from similar organic or semi-metallic pads. Despite the name, they are nowhere near 100% ceramic, and still contain anywhere between 10% and 20% metallic content (depending on whose pad it is).
Because they are designed to replace your factory brake pads, they are no more difficult to install than regular brake pads. In fact, the install procedure is exactly the same: You loosen the lugs, jack up the end of the car, remove the wheel, undo the two caliper to caliper mounting bracket (torque member) bolts, slide/pry/knock the old pads off, put the new ones in its place, then reassemble everything the same way you took them off. If you have a tool kit with a rachet, a medium sized C-clamp, and a jack, it's very easy.
The main advantages to pads with ceramic content are supposed to be noise reduction, reduced rotor wear, and less brake dust. All of these advantages are supposed to come without a reduction in braking performance (for street use in a passenger car). Usually, the first two claims turn out to be true (the claim that they dust less isn't actually true. The dust is just a lighter color and they don't stick to painted surfaces as easily so it just seems like there's less dust).
Some manufacturers, however, reccomend that their ceramic pads not be used for towing or extended periods of hard driving. Keep that in mind if you're one of those types that like to tow their quad everywhere or want to autocross on your street pads.
What it all comes down to is, if you're looking for a nice set of brake pads for your daily commute, ceramics are a pretty decent option. If you want performance pads that you can really drive hard on, you might not find what you want in your average ceramic pad.
ceramics
try looking here http://brakes4u.co.uk/ebc-brakes-automotive-parts.asp
i had some of these and unlike other types of ceramics i have found these to be far and above the best ive used and i have used a few.........as to the low dust issue you will always get some dust with organic pads
but with these instead of cleaning wheels once every 2 or 3 days i was giving them a quick wipe every 4 weeks as stated before the dust does not stick
but braking is superb great initial bite and no fade and the braking gets better through the life of the pad
well worth a look
Will work for beer
Raybestos will be fine for general driving. I wouldn't tow anything heavy with it, especially in the mountains...
The EBC post above was referring to the link above his.. Some people think EBC are the shiznit, and the rest of us stay away from them at all costs. ;)
Not Anymore.
For a second I thought they were indicating the EBC pads and I was like No0o0o00o00o! EBC means Extremely Bad Compounds, expecially their cardboard Greenstuff :p
Will work for beer
Yup, exactly..
I've used the Raybestos on my wilwoods and they're okay. great for street driving, but much lower friction than all the other compounds I've run (which is about 10 different compounds now). When I really beat on them, they would fade, but in order to do that on the street, it required driving that would send me to jail if I got caught- so for street driving the Raybestos are just fine. :)
Here's the list of pads that I can remember off hand, and the order in which I rank them:
Street:
Ferodo DS2500
Wilwood Q (Raybestos Quiet Stop)
Hawk HPS
Hawk HP+
Porterfield R4S
EBC Green
Track:
Wilwood E
Wilwood H
Wilwood D
EBC red
Hawk Black
The only thing I hated worse than the EBCs were Hawk Blacks, because they ruined a set of brand new Skyline rotors in one event. :mad:
Not Anymore.
You gotta throw Carbotech Bobcat in the street compound in there too. They are excellent street pads with great initial bite, less dust than metallics, long life, easy on rotors, awesome fade resistance, quiet and have a relatively low cost. I much prefer them over Axxis and EBC.
I think I am gonna go for the Panther XP-9 for track usage down the road. Their coeffecient is something like .60...its a pretty mean pad.
Will work for beer
I've heard nothing but good things about Carbotech, but I haven't used them personally. The list above are all the pads I've used on these calipers and rotors. You can throw in another huge list of all the ones I've used on the stock calipers.. Raybestos, Bendix, wagner, Axxis, Porterfield, Hawk, Perf Friction.......
those above were all the ones I've used and can directly compare because they were on the same car, calipers, rotors, etc...
Cool thing is I've bene through all of those pads and I have yet to have to turn my rotors. :) I'll definitely be buying Coleman rotors again!
Will work for beer
they're 2-piece. I'm not sure who made the hats, but I *think* it was Coleman. I bought the hats from Fastbrakes- same ones they use on their Maxima 12.2" kits, but I'm using 13" rotors with it.
http://www.colemanracing.com/
I can't compare them directly to Stop Tech, but Coleman is known to be one of the best in the industry. they're used more on race cars than street cars, but obviosuly work on the street as well... (not to be confused with track-only brake pads like the Hawk Black!!!!!)
Not Anymore.
Now I'm interested in them. I think I'll lurk around on their site and see if they make rotors to fit my 02 B15. Thanks :)
1 - 20 of 21 Posts
