1 - 11 of 11 Posts
HELP!!!!! I have been hearing this anoying clinking/rattling sound coming from the catalic converter for the past 2 weeks.... Its weird cuss it only does it from 2000 to 3000 RPMs.... I was just wondering if cats can break on the inside or if they just go bad... I figure it can break considering its porsalin on the inside. But have any of yall had yours go bad??? Im at 100.000 miles so could it be cloging????? Thanks for any imput!!!!!!!!:D
Cone Dodger
internal breakdown of cat, not too strange for a high mileage car, what year is your car again??? is it under the car or under the hood???also consider changing out the o2 sensors as well if you haven't yet.......
Discussion Starter · #6 · (Edited)
i was asking if you could break it cuss i bottomed outin a frends drive way and put a big dint i the cat but i also wanted to know if it wares out ver time...
I don't know about that one
But my car has 100,000 also, and from time to time I got to get
underneath it and throw some radiator screw clamps on my exhaust pipes heat shields.I have to tighten them up to get rid of the rattling from rusting places where they connect cause their loose. About 2 years ago, I hear this thin metal banging noise going down the road all of a sudden, pulled into a parking lot and looked underneath, and saw my cat. heat shield cover hanging with only two of four mounts hold it.At that point I just knocked it off. Check your exhaust real good, some of my heat shields would only make noises at certain RPM's to. And yes, Michigan is the heartland of the rust belt. I just find it amusing that the big three are headquartered here.
Cone Dodger
then if there is physical damage, then you must've dislodged something in there......hence, the rattling..........and as far as i can remember, the oe just bolts on, no biggie.......
1 - 11 of 11 Posts
