1 - 20 of 43 Posts
i am in need of a exploded view of the carb on the Z24i motor. i searched on here and the internet and can find nothing. if some one has the means to post this in here that would be great. i have been battling a no spark issue and have got that fixed. and now the issue is fuel. i have fuel to the carb but noting in the carb. i need to know how this carb works so i can figure this thing out, and get to driving this thing.
thanks for all your help!
got ICMs and a new battery.
Hardbody Freak
check power to the injectors..
i know on my 86 truck the crimp in the service loop (wire harness) had corroded..
thus interupting the power to the tbi..
about 6 inches b4 the tbi plug ..the wire harness has a kind of loop ..
in the loop the 2 tbi wires are crimped to the one power wire coming from the ecm
i will look at that tomorrow after work.
are there any good places online that have good wiring diagrams??
thanks.
i have looked all over the net and found nothing.
things are hard to find for this truck......
oh should i have battery voltage or a ref voltage at the tbi connector??
will i tested both connectors at the TBI at the 4 pin connector i had 3 dead holes and 1 battery voltage.
and at the 3 pin connector i had only 2 pins that were used but it was a 3 pin style connector which i had a 5volt ref voltage.
the 4 pin was at the driverside and the 3 pin was at the back.
and the colors on the 4 pin were black and green with different tracers.
Discussion Starter · #11 ·
that was key on.
and not sure what you mean with the last thing you said???
ecm side and tbi side??
Discussion Starter · #12 ·
also there was some type of metal strap that was around the wires in the plastic casing that ended about 3 inches before the connector. is that just sheilding for the wire??
Discussion Starter · #14 ·
tested a few things tonight.
first fuel volume. it was great!
second fuel pressure and that was at @28psi
not sure what it is supposed to be but for a TBI setup i think 28 is plenty.
tomorrow im going to be putting a noid light on the injector plugs to see if i have pulse.
Discussion Starter · #15 ·
well it ran for about 3-4 seconds tonight. on carb cleaner and the injectors are defintly the cause of the issue. probaly from sitting for a year and a half.
Ahhh injectors, a very problematic part when left to sit. On my 68 510 project the injectors stuck open and flooded the 16v KA with fuel from oil pan to valve cover.
Discussion Starter · #17 ·
narrowed it down that it is infact the injectors. they are getting pulse and fuel but nothing out of them. so i am going to take them out of the truck and try to clean them. if that does not work i will have to source some injectors.
anybody....:rolleyes:
Discussion Starter · #18 ·
took the injectors to work today cleaned them and pressured them up there and ran some injector cleaner threw them and they worrk great.
here inlies the problem:
i have reinstalled them in the truck and still nothing??? i am at a complete loss here. when i tested to see if they were getting pulse from the ECU they were. i will have to get my noid light from work tomorrow and test this again. i am not sure were to go from here. i guess if they arent pulsing for some reason now that will be one road to go down, but if they are this thing should start!?!???........right:confused::confused:
Discussion Starter · #19 ·
i have power to the injectors but no ground to them. i have ground and power pulse when the pigtail is not plugged in the the injectors, but when i plug it in i lose the ground and the pulse goes to 12v all the time on all the pins??? its like the injectors are internally shorted out? is this possible?, or do i have a failed ECU that is not suppling ground.
i have had them out and cleaned them and they fire fine on the bench when power is pulsed to them. so i put them back in the truck and i get nothing. i also tried clear flood mode and still nothing. i am not all that familiar with the Z24i set up so any help with this would be great.
1 - 20 of 43 Posts
