1 - 12 of 12 Posts
I have a 98 200sx and the car flooded. i put a new motor in and the only things that stayed the same was the trans the mass air and the distributor . the car does not have any spark.I checked the ecu ,its good . I can jump the coil and make it spark but still the cars dist seems to have no power.Please help and thanks in advance.
What are some of the things to check on the dist.
and do you mean you cant short out the sensors with the flood because i sure hydrolocked the #4 cyl.
ok, i was under the impression that you thought you had 'flooded' your car with gas ;),
check the ignition control module.
sometimes even a bad coil wire will cause it.
you said the coil can produce a spark, what color is it? your looking for a white-blueish spark, if its red or orange, then you have a bad coil.
to be honest, im not sure. i know on fords, it is screwed onto the distrib. on my E16I i think its actually part (built into) the distributor. call the dealer and ask them where it is....dont give em your credit card number tho LoL
1 - 12 of 12 Posts
