Been a while since I've worked on my Z.. as the weather is improving, I've finally been able to pick the project back up.
The battery recently died on my 84 300zxT. I tried to use a jumper box, but accidentally had it on the 50 amp jump charge. I'm worried I fried something, or definitely did.
The car currently starts (new battery) but dies the second I let the key to the run position. The distributor has power leaving the key in the run position. Thoughts, and ideas on diagnosis?
Thinking it may be an issue in the ignition switch, but would that not be the case as the dist has power in run? Am yet to check fuel.
Sent from my PH-1 using Tapatalk
