hello, i'm brand new to the forum here. my name is jake and i'm in alaska, i have a 97 sentra xe with the 1.6L auto and just shy of 205k miles. i'm kinda in a deli ma with the car. i bought it just over 2 years ago and had to rebuild it, it was in a front end wreck. i've put about 73k hard miles on it sense i've had it. it's eating oil and coolant now. the oil issue has round 10k miles ago that i can remember and the coolant started less than 1k miles ago when the car over heated. there was a major lack of fluid in the radiator and it show'd no warning of this. i don't know where the oil or coolant it's goin, not on the ground from what i can tell and none of my friends have told me bout blue or white smoke come'n outta the tailpipe. i've just realized last night that i'm missing half my belt to my alternator so i'm fixing that asap but i thot sense i'm doin that i'd change the timing chain also sense i never have and have never been told it's been changed at all. well, i'm being told there's 2 chains and it's prolly the tensioner and guides that would need changing instead. the car isn't making any weird noises. but recently while i've been driving the heater turns cold and i can see the temp gauge jumps up just a little bit. you almost can't tell it does if ur not pay'n attention. that's when i noticed i'm pretty much driving on the battery cuz if i hit my brights or the fan kicks on it dims the dash lights quite a bit. the last car i had was a subaru and when the heater turned cold it over heated and cooked the engine, it did it with 2 engines and we never figured out what the problem was. i'm try'n to avoid that happening again. i've been told that i might want to look at replacing the water pump too. i don't know the signs of that goin out at all. i've come to realize that these parts are not cheap by any means and i'm running on a very very tight budget. the car is also due for an oil change and i use mobile 1 synthetic 10W-30 with a fram filter.
now that i've given u the opening chapters on recent events with my car, i need to know what your opinion on what's goin on with the car, what i should fix or just put a new belt on it and put a for sale sign in it, and if possible where i could go for cheaper parts than napa, carquest, or shucks cuz those are my parts stores options without goin to a shop. and i'm limited on junk yards too, not very many round where i am, i'd get lucky if they had the same car in like 1 or 2 of the yards, let alone the same parts i need and in decent condition and any cheaper than the parts store. if you could also throw in any other 2 cents on the matter that'd be great too, thanks a lot in advance and for reading all of this.
