I HAVE A 99 SENTRA SE. I LOWERED IT USING EIBACH SPROTLINE SPRINKS AND KYP SHOCKS AND STRUTS. SINCE THEN I NOTICED THAT INSIDE OF MY FRONT TIRES HAVE BEEN GETTING WORN OUT FASTER THEN THE REST OF THE TIRE. I KNOW THIS IS PORBLEM DUE TO POOR CAMBER. I WANT TO KNOW WHAT THE EASIEST WAY TO FIX THIS PROBLEM IS?????????????????
It's not the camber it's the toe. When you lowered the car it made it toe out that's killin the tires. I run 1.5-2 degrees on the street with no trouble at all.
How did you adjust your toe.. Did you do it or have a shop do it. How much did it cost you if you had a shop do it
It's the tie rod end's that are adjusted. Do it at a good aglinement shop the first time. I run 0 to 1/8 toe out on the street. Hope this helps;)
