1 - 16 of 16 Posts
Please Shift Here
What causes the brakes to seize up? My friend has a 240 S13. 4 brand new rebuilt calipers and a new Master Cylinder. He says when he brakes, the brakes continue to hold even after he lets go. They slowly go back to normal after little while or a bit of driving.
He told me it might be the distribution block on the firewall, anyone have any ideas?
Erin Go Bragh!
What about the fluid? With rebuilds the fluid levels are sometimes not checked thoroughly. Not saying your friend doesnt know his sh*t, just a common mistake.
Please Shift Here
Nea, we just reflushed it Friday. He uses DOT3, but here's the deal, he doesn't know that much. When he did his brakes, he didn't know you needed crush gaskets around the banjo bolts, his brakes were leaking like a mofo, and he was so lazy, he jus kept getting brake fluid and refilling the MC everytime the light went on. I got some crush gaskets, fixed the leaks and re-bled.
He said they've been seizing before, but it's even worse now.
Erin Go Bragh!
He said they've been seizing before, but it's even worse now.[/QUOTE]
Sounds rough. All I can think of is distribution block or brake lines. Does he have the FSM manual? Sh*t, maybe even a Haynes manual could give some troubleshooting tips! :crazy:
Boxed Fox
Have you tried adjusting the brake booster preload? You can change it by loosening the lock nut behind the brake pedal and turning the rod that goes from the brake pedal into the firewall. If there's too much preload, the brakes could just be dragging (and the pads/caliper could just be getting knocked back into the caliper while your friend drives).
Erin Go Bragh!
we finally figured out it was the booster. it got replaced.
Its about time :D
What kind of car does he drive? I am curious as to wether or not this could become a future problem with my car.
Please Shift Here
Discussion Starter · #16 ·
Like I said above, it's an S13 240sx (1990 w/ SR20DET swap to be exact). Had all new calipers and a new master cylinder. We bled the crap out of the brakes with DOT3. Eventually, it got to a point where he had to tow his car, the brakes locked up so bad, he couldn't move.
he brought it in and it was a bad booster. Replaced it, it stops better than ever.
1 - 16 of 16 Posts
