1 - 9 of 9 Posts
With the SR20 S13 Redtop running 86mm pistons, would you have to sleeve the block if you bored it .20 over? (86.5mm pistons) Or is that more "just to be safe"? I know you HAVE to sleeve it with 87mm pistons. Being it an aluminum block and all...
Thanks guys.
Thanks guys.
You don't have to sleeve it to bore it 0.5mm (0.02") over. I did this with my shortblock, and am using 86.5mm CP pistons.
Mekanik22 said:
What is a torque plate, where does it attach, and where can I get one?
It is a thick metal plate drilled for all the head bolts and cylinders. It is tightened to the block like a head to produce the same stresses on the block as the head would.
To be best of my knowledge, they are not commercially available for the SR20. Jim Wolf Technology has one they use for building engines. Try contacting them.
Lew
Locked and Loaded
so does JGY customs. and they do the services too.
Pivot 180
The SR block actually twists slightly when the head is attached. The torque plate simulates this twist. If you dont use it when machining, the bores will be out of round when you put the head on and the engine will pop. So when the torque plate is removed and the block is free of any load, the bores are actually slightly out of round.
1 - 9 of 9 Posts
