1 - 20 of 27 Posts
hey guys i just went out and bought a manual boost controller for the 300zx and I figured you guys could tell me a few things about installing it to save on having it installed "professionally". first question : how do I put this thing on? and second : about how much time does this take to put on? thanks a lot.
Banned
Well first I wouldn't trust the one you had, and the stock one only reads to 7PSI so you better hold off for a bit.
Banned
It held 10 PSI for about 2 weeks then started slipping. Now it depends on weather conditions if it'll hold or not
Z31 know-it-all
BZZT!!! Stock gauge reads to 13.5 psi. But they are not very good.
You should get a full sweep gauge so you can better read the numbers.
Z31 know-it-all
hondakillerZX said:
what is a full sweep gauge?
I don't recall seeing a boost gauge that isn't full sweep, but I'll use the oil pressure as an example.
Full sweep:
Partial sweep:
Banned
Partial sweep guages are mostly for applications that don't require much movement, and display more constant information. Oil pressure, voltage, coolant temperature.....that sort of thing.
Full sweep guages are more in general use for things that change constantly. Boost pressure, EGT, rpm, etc. And requires more area to accurately display those changes, which can vary more widely.
So yes, it's more likely than not that a boost guage would be full sweep. Even one that does not also display vacuum.
1 - 20 of 27 Posts
