In Perfect Condition! No dings on pan! It includes the Upper & Lower Oil Pan!
$100.00 shipped! Email me @ [email protected]
Just let me know!1CLNB14 said:I'll talk to the DET owner on my team. He may be interested.
This pan was off my old SR20DET. I am not longer running a DET block! I am now running a full built G20 Block mated to an SR20DET head!Sunny J Reg said:Louis - what's up,
Where did you find such a clean pan! That secondary pan is gold..I'd hold on to it. All of my DET pans were always dented.
I tapped the block for the Oil return, but not for the oil feed. I am feeding off of teh oil pressure sending unit. I am still running the water cooled oil cooler off the pressure sending unit.Sunny J Reg said:I take it you drilled for the feed and return lines.. or did you go NA this time?
Curious if you swapped over the water cooled oil filter neck![]()
I should have it in my possession this afternoon. I will put the kit on the car this evening. The manifold will be the same manifold used in the new kits, but I have other parts that were custom for my car. Here is a list of what my kit consists of:Sunny J Reg said:You gotta post what Spangler is up to.. I'd love to see his new kit.
