I am doing a head job on my truck. Your thoughts and comments are greatly appreciated. Thank you for your help.
The truck was overheating and began to experience a severe loss of power which got worse and worse (over about 10 minutes). Eventually the heat gauge started to redline and I cut off the engine. I then had it towed to my mechanic. My mechanic said it had a blown head gasket. I wanted my mechanic to do the head job, but he is too busy so I am taking a crack at it. (Edit note: This paragraph was edited because I remembered details.)
This is the first time I have done internal engine work. I am experienced with replacing alternators, brakes, rewiring an engine and small engine repair.
I purchased the shop manual from Nissan and have been watching head gasket repair videos on Youtube. I have also been reading books and forums on head gasket repair.
My goal is to do a clean, high quality job and get another three decades out of the engine.
My plan is to:
1) Clean the engine
2) Document the locations of each bolt I remove with video and a marker/masking tape
3) Wedge the timing chain and examine it for wear
4) Take pictures of problematic parts for your feedback
5) Take the head to a machine shop for their opinion
6) Have the head magnafluxed
7) Have the machine shop remove and examine the valves
8) Use Nissan replacement parts
I will post more of my thinking plan as I learn more.
Here is a link to a simple Youtube video I did of the engine compartment:
Here are a few pictures I took before I start following the Nissan manual and taking things apart.
My plan is to:
1) Clean the engine
