I believe it was on cardomain.com that I seen it, I think it was NX1000 front disc brakes will bolt up onto the stock 200sx se brakes and there bigger? Not sure whats up anyone heard or done this? easy bolt up or mods needed? leme kno thanx
2018 Nissan Pathfinder SL
Search for AD22VF here on the forum, this is the caliper model number.
Fitted to
NX2000 93 with ABS made in Japan
Just tell the parts guy this is what you want.
No you do not have, or need ABS to use these.
I got mine from Rockauto.com
Powered by natural gas
Easy as 1,2,3.
1 Buy Quality loaded 91-93 Loaded Japanese NX2000 calipers, w/ABS, and QUALITY rotors.
2.Use metal snips to trim dust sheilds. You MAY need larger rims to clear the calipers.
3. Install components listed in step one, bleed brakes. Rinse and repeat.
I will submit this again, just save $ and buy hawk pads. This will improve stock braking greatly(and i only have them in the front, so far). I have drums in the rear but haven't looked back to upgrading brakes any further than when the rears get ready to putting hawk pads just in case it would make a slight percentage of a difference as 80 percent of braking is on the front. And yes, it was a night and day difference between the stock ones when i bought the car and hawk pads.
