Hi all, I've got a 2009 PathFinder (4.0 4WD) at 200K miles with the original Nissan radiator. It busted, and miraculously all of the transmission fluid pushed into the coolant, but no coolant entered the transmission. Is there a good trick to flush it all out?
(I popped the transmission cooling line off of the radiator, ran the engine, and purged all of the trans fluid out. I also dropped the transmission pan. It had about 3 quarts TOTAL in the system, and there was no antifreeze in it at all.)
