have a few questions about how to set base timing on the Z24i motor in my 86.5 HB. I was just wondering what you have to do to set the base timing on this thing as i just did a lot of work on the ignition side of things including the dizzy. i think that 5 degrees on the stationary at operating temp, correct?? (that is what it says on the hood.)
i have searched on here and found a lot on the KA motors but nothing on the Z24 motors at all. and the chiltons manual that i have has nothing in it about how to set the base timing!! so any help would be great. thanks!!
thank you sir.
so i dont have to do anything special to set the base timing??
oh i see.:rolleyes:
thanks!
Iwould get that timing light out and set it at least 10* btdc for that xtra pep! I got my cam degreed in at 3*advance and the ignition is set at 15* btdc. Start once it fully warmed and adjust it via your distributor loosen the two bolts and have at it! Of course you'll need to watch the crank pulley with a timing light...GL
