With My swap and B15 transformation of my B14 I found that the nismo rear sway will work with the B14 rear beam axle.
The B15 rear beam axle will dirrectly bolt up to the B14 chassy.
This means for all you peformance braking and handleing junkies that yes you to can have a larger lug pattern and larger brakes in the rear.
And yes you can use the nismo rear sway on your b14!!!
Might want to sticky this!
