dho said:
How do the 205/60R13 R tires feel on the track compared to the 195/50/15's?
The 13's are Toyo Proxes RA1's. The sidewalls are a bit soft, so with 38psi in them they are about as responsive. The grip is hands down easily
WAY higher than the 712's. If you've never run R tires before, you really don't know just how massively fun they are.
Also posted by dho
I had the fender cut and tucked but it didn't touch there, it touched kinda where the top of the wheel well is.
Sounds like your rear springs are too soft, or the tires are too wide/tall. What is the offset of your rims? OEM is 40mm. I run 38mm and I have no rubbing problems at all with 195's.
The stiffness of the struts should not affect the rubbing, once you are into a steady-state corner, and all the weight transfers to the outside, the strut will comopress with the spring until everything stops moving - if there is no movement, the struts aren't doing anything. I think it's a spring issue (or offset issue).
dho said:
Do Z rated tires give better traction/handling than V rated tires?
Generally speaking, increased speed ratings are merely the construction of the tire being able to withstand higher speed/centrifugal force. Most higher speed rated tires come with softer tread compounds, which would improve traction too. To throw a wrench into the "Z tire is better" theory, my race tires, clearly stamped "Recommended for competition events only" on the sidewall, has no speed rating whatsoever.
dho said:
I don't know how to describe the steering... if feels neutral some days, other times it kinda feels like oversteering, and the other times it feels like understeering.
Could be your driving. Try taking a freeway on/off ramp at a steady speed and see what it feels like. There are many lists of suspension/handling tuning tips on the net and in books - try to find out where/when it consistantly understeers and oversteers. If its inconsistant - it's you, not the car.
