1 - 7 of 7 Posts
Banned
did you search?
a WAI sits in the engine bay and breaths the warm or hot air......with hot air it is thinner and more pron to premature detonation. a CAI gathers air from out side of the engine bay where the air temp can be much cooler. the general understanding we have is for ever 10* drop in intake air you get a 1% HP increase. on top of the air temp you also are completely opening up the intake tract so it doest have to work as hard to pull the air in (more HP gained) also, many of the top brands (place racing, hotshot) tune their intakes, this means at certain rpms it will create a ram air effect and give you even greater HP numbers, this mostly happens at highway speeds though.
The Classic Collector
Response
A cold air intake works by taking in air from the outside just like a regular air intake. The only difference is that the cold air intake's performance depends on the outside temperature. If it is cold, like below 50 degrees, your CAI will work very well, but if it is hot, it results in low performance. The average hp that I have seen people gain from these after market intakes range from 2-5 hp. Some market claims of reaching 10 hp with their intake for the B13 sentra isn't true.
100NX2000
And where did you hear that? I swear AEM was making close to that with their highport intakes?
Your electrical friend
Grassroots Motorsports Magazine got a dyno proven 10hp out of a $40 eBay WAI on their B13 SE-R. A CAI is a decent bit more work to install than a WAI. Honestly, I wouldn't spend the money on a Hotshot or an AEM. I'd buy an eBay WAI and get a cheap CAI for a honda at the parts store for another $50-$60 and use that for your MAF to filter pipe. I highly doubt that if you dynoed a setup like that then swapped in a hotshot or AEM that you'd see a big difference between them, and not enough to justify spending a couple hundered on it.
1 - 7 of 7 Posts
