1 - 14 of 14 Posts
Ex-mod/nissan guru
check the offset for 205 cuz it could be rubbing... (i had those) in the back... against the molding plastic trim that goes inside the fender... well you could easily take a grinder and shave it...
Still moderating..sorta
If you want your speedo to be accurate you should use 195/55R15. Also, before you buy make sure that the wheels fit on the hub. Nissans have bigger hubs then Hondas so sometimes there are some fitment problems
Nissan/Mazda Gumshoe
205/40/16
hey man. im running 16s with no problem. of course u will have to get an alignment, but i ve also replaced various suspension components such as tie rods , tie rod ends , ball joints and the struts. so in the long run on cars our year span , the alignment is going to happen . u might want to take a look at some of these parts pretty soon. there not all that expensive and u can change them ur self with just about any old socket set. thats just my 2 cents........
Discussion Starter · #11 ·
getting it from a local place.. but I think they have group buys on www.groupbuycenter.com.. getting a set for $370.. I was trying to get 17" subzeros for my spec-v but they haven't been able to get some for two months.. so I thought I would play w/ my b12 and I'm starting to clean it up after many years..
1 - 14 of 14 Posts
