1 - 20 of 21 Posts
that seems like a lot of fabricating the best thing i can say is just gofer it, find out step by step what u need to modify to get the engine and transmission set up and dont u need a sr20ve ecu? just curious
I'm getting the ecu reprogramed, I think it won't work if it's not.Ohh and yesterday I bought a Walbro 255 inline fuel pump :thumbup:
Correction, I was told that the DE ecu can work but it would give some idle problems, which I would have to correct by hooking up an APEX SAFC II, and I wanted to know if any of you guys knew if the shifting linkage would work with the SR20 tranny?
100NX2000
I am so here watching the progress of this car. I have confidence that this will work somehow because I see some sick cars come out of PR. So please post pics and keep this thread updated.
Thanks for your support guys, I'll keep you informed on my progress, there are some pics of my here ( http://www.cardomain.com/memberpage/587017 ) :showpics: none of the from the swap yet, but i'll post them as soon as I start bolting and modifiying everything Thanks again...
This is a list of what I got...
*SR20VE 95'
*G20 SR20DE Wire Harness
*G20 SR20DE ECU
*Walbro Inline Fuel Pump 255lph
*Nismo Fuel Pressure Regulator
*New Blue SR20VE Valve Cover
*91-94 SR20 Tranny with LSD
and I'm still on the lookout for a few other parts I need
i recommend against using the AFC or stock ECU.
get a JWT ECU, order it with either no rev limiter or 8000 rpm, and just tell JWT that you are aware of valvetrain damage and that you will eventually upgrade the cams.
also, go here http://www.sr20forum.com/forumdisplay.php?f=41 and read the FAQ, etc.
Discussion Starter · #12 ·
*SR20VE 95'
*G20 SR20DE ECU
Made a mistake it should read
*SR20VE 98'
Ex-mod/nissan guru
about the VAFC stuff... you should use more like a MSD rpm trigger instead... youll need 2 of them (confirm this) cuz you get 2 point where the tensioner moves and changes cam timing ... Good luck with the swap !!! hope i can help you more later !
1 - 20 of 21 Posts
