cool info(3) Do you recommend stainless steel brake lines? What are the advantages and disadvantages?
The primary purpose of stainless steel braided brake lines is to improve the brake pedal feel, i.e. to make the brake pedal firmer. Stainless steel brake lines are typically constructed of a PTFE (teflon) core - through which the brake fluid travels, which is covered with a nylon or kevlar braided sheath, over which stainless steel fibers are braided on the exterior. Some stainless steel brake lines also have a silicone cover applied over the stainless steel braiding, to prevent dust and debris from working into the space between the PTFE core and the stainless steel braiding, which can wear down the PTFE core, and thus result in brake line failure.
For a street driven vehicle, we recommend NOT installing stainless steel brake lines, as they require more "maintenance" than OEM rubber brake lines. By maintenance, we mean regular inspection for leaks or wear. The stainless steel braiding provides protection against road debris which could otherwise cut or rupture an OEM rubber brake line, but unless you are willing to inspect your brake lines every 3 months or so, installing stainless steel brake lines would present more of a liability than any realistic performance benefit.
For a track driven vehicle which has its brake system inspected regularly, and where the driver wants the most consistent and firm brake pedal feel possible, then stainless steel brake lines can be installed with excellent results.
That's not an exception, that's awesome that they're DOT aproved.NickZac said:I have the Goodrich SS lines and they are excellent. They are one exception that can be driven on the street as they are in fact DOT approved for street usage. It is still important to inspect them every so often.
you got what I was sayinGalimba1 said:That's not an exception, that's awesome that they're DOT aproved.
Like what model are you thinking of? Basically, to increase brake performance, you want to improve brake pressure or friction surface area. The latter is really expensive (aftermarket rotors + calipers = $$$)hampeh said:how about changing brake pump to other model...
Read the brakes sticky at the top of this forum. The guy that wrote it was building a bee one one.hampeh said:how to improve braking system for b11....
want more grip better than standard...
actually i want minor modification...
I dont see exactly why you want to do that unless your cars are very heavy in the rear, but using a meaner pad in the rears will let them bite more.hampeh said:i wanna to adjust my rear brake make more grip....
so that, when i press brake pedal, all my front and rear typre will stop....
so i'll get more grip...
it is posible....?
if posible guide me....
EBC Greenstuff is the most horrible compound out their. They fade way too easily, they have been known to crack (edit: well actually crumble), their life is incredibly short, and they leave the oddest crap on your rotors leaving you with no other option to turn or refinish. Organic compounds in general suck and IMO are not all that safe. EBC is by no means a good name in brakes. And they begin to fade closer to 600. Stick with Ceramic or sem-metallic, preferably with decent carbon compounds if you want strong fade resistance. Hawk is better, Axis is good, Carbotech IMO is the best. I drive the Bobcats and if you look at the NPM test of them on the Nissan Titan, those tests will concur about the quality and ability of the Bobcats.omnimedia said:EBC green stuff brake pads good for heavy braking, alot less fade, dont heat up very fast can take 2000 degrees. get theese for your front discs. i found green nissmo pads on ebay for the rear drums.
green brakes are a composite mixed with kevlar.
less dust as well. great upgrade if your keeping your rear drums.
And it just hit me that you probably have drum brakes so I honestly dont know how to change bias without getting rear discs.hampeh said:i wanna to adjust my rear brake make more grip....
it is posible....?
