ive done it about a month ago...
here wath you need....
- manual tranny
-flywheel and clutch kit (better buy a new clutch)
-Ecu from a manual b12 of same engine
-Drive axles : auto arent the same seals.. wont fit trust me !!
and its not even the same lengh !!so its the 2 of
them youll need !!
-2 motor mount :the mount that bolts to the frame on tranny side
(the auto one is 2 inch to much forward its a pain in the ass to get the rubber mount to get in it + the axles get a real kick cuz it get squeezed...trust me hahaha)
the back-engine one ... the auto one doesnt have the place to bolt the stick stabilizer bar to it plus, there is a upper link that retain engine from hurting the firewall... so you have a choice there...
- Pedals (brake and clutch)
those are a pain in the *** to bolt... the clutch one already got a treaded hole below dash, so its simple but you have to squeeze in the air dock.... the hole in the firewall is already there..
the brake pedal, just get the one that there out and put the other one in... tricky for the spring... ive used tieraps to get it there to hold it... youll see!!!...
-clutch cable wich is easy task... make sure you got the little plate that bolts on firewall engine side (it bolts with the 2 other bolts from the clutch pedal...
-stick shit assembly (make sure you got all the hinge that goes inside the car... there is 2 of them...if you pry the carpet near the stick auto, youll see white large caps that protects the carpet from those screws, they are there cuz nissan make all theyre b12 ready for manual...)
Ps... its all bolt on !!... even the stick shift!!... to get the auto stick out... you must unbolt it...if it doesnt go well (like me)you drill the bolts from the inside of the car(bigger to cut it) you buy new ones (ive got stainless) and you get a friend to put it back..smeone below and the other inside to bolt it on...
THERE is ABSOLUTELY no hole to drill of any kind !!!
and like my friend ricebox said its a lot lot lot of work !!
it took me about 20-25 hrs to make it (sure i didnt know how to get that fu**** auto tranny out but now im pro!
Have fun !!
