Since purchasing the R51 the following issues have occurred over eight times:
1/.....Brake Lights do not Work whilst driving.
2/.....VDC warning light stays on whilst driving, cannot turn it on.
3/.....Cruise Control stops working and flashes.
I have posted videos of 1 and 3 here YouTube - frehnejc's Channel but 2 doesn't seem to happen anymore. The car has been back to the dealer a number of times and they cannot seem to fix it. Is the Aussie Pathfinder only made in Spain or are the US ones also made in Spain?
Any ideas on how to fix this issue?
The VDC light can come on when the MIL's are tripped as well...see below for the DTC code diag procedure...
If you get any MIL codes I can give you more information..... just let me know....
CHECK ENGINE LIGHT RESET/DIAGNOSTIC PROCEDURE
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats itself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
Clearing
You can clear the code (and the annoying MIL) by holding down the accelerator pedal for more than 10 seconds while in Diagnostic Test Mode II. When you release the pedal, the ECM erases the trouble code(s).
