1 - 20 of 20 Posts
What is Seven Ten for?
Partyboy25 said:
It seems impossible to find any tail lights for my 96 200sx se. Can anyone help?
it is impossible, there are none. A search would have told you this, it has been beaten to death. However if you MUST have a differnt set of taillights, you could always fab something up and make it work. I've seen a 200sx with skyline tails, so the sky is the limit.
As I've said before, we need to sticky this!
Banned
Banned
Jaralaccs said:
what are you talking about, they dont make covers for the 200
you can buy the sheets in diffent sizes then simply cut them to size........either do that or leave it stock.
click here they have 4"x8" up to 12"x 24" you can also choose between 20% tint and 35%
Banned
hey i never said there wouldnt be consiquences lol.....but if you get a wild hair up your ass to "get custom tails" that is the oly thing you can do. also if you get pulled over they will simply pull off....hell you could do it with the po-po standing there. remember that stuff that was big for awile? (i still se it now and then) it was that tint you put on the inside of the window and it was rubberish and just stick there? (no sticky side though) well i suspect that is what this stuff is.
Avtomat Kalashnikov
  • Start by removing the light bulb from the housing.
  • Preheat the oven to 325 deg.
  • When the oven is ready, place the headlight housing onto a baking sheet and put it in the oven for approx. 2 min (you might need to repeat this step until the silicon is pliable enough to work with)
  • Remove the housing from the oven (with the pan it's on)
  • Place the housing on the counter or whatever surface you choose (we used a towel) and put the baking sheet in another spot as you will be using it again
  • Use the blunt side of the knife to pry the outer plastic piece away from the housing. You will need to use the heat gun/blow-dryer at this point to help you get it apart. Also, be aware of the little clips and be sure to unclip them without breaking or melting them
Banned
but you can mess that up very easly. you could pool it too then there would be dark spots when your lights come on.
B14_Stealth said:
just got another set to the tails from ebay and tint those with Night shades. That way if you mess up, you can always go back and put the original ones back in.
I think I'm gonna do that to my altezzas
Discussion Starter · #19 ·
Ok, if they can get these other companies to make new stuff for the ga16 then why cant they get someone to make aftermarket tail lights for a 200sx??? It cant be as hard as making (i.e.) aftermarket cams :waving: ...is it just doesnt make any sense to me :confused: am i the only one that feels that way???
no your not but its just hard to come up with around 100 people that want the same style tails
1 - 20 of 20 Posts
