My Transmision just started to popout last week.
It started doing it after I opened it to change the main shaft seal. It never popped out before.
I need to know what are exactly the parts that wear and start the popout or if you guys have any idea of what I could have assembled wrong to start with the popout.
Thanks in advance
2018 Nissan Pathfinder SL
I know there is / was a fith gear pop out kit available from Courtesy Nissan.
I suspect its just a difference in alignment from when you re-assembled (from my RWD days)
What is there to align? I think everything goes just in place without any option for alignment. What should I correct?
Yes you are right; but everything has tolerances, and it possible a small change might have made your problem come a little earlier than it would have.
