I have a 92 sentra Auto tranny, the 1st gear is ok going to 2nd. Under 2nd gear its fine until it reaches 2000rpm it will start to slip revving up to 3000rpm before it will shift to 3rd. At 3rd it is also ok. 4th is the same as 2nd. It will slip in 2000rpm and higher.
Fluid color and level is ok, nylon governor gear is still in one piece.There is a leak in the pan but only for the first 2 mintues after starting the car. I also noticed that the ATF fluid have bubbles everytime I checked the dipstick is this any indication of problems inside the tranny.
Hope you could provide any options I could check before I have a complete tranny change. Thanks in advance.
