oh man kid. youll want to get a wide band a/f guage. and its easy to install. youl have to probably drill a hole into your exhaust before the cat. and installi want to buy an A/F gauge and i need to know if i need a wide-band or a norrow band one and would like to know if it is hard to install because im not good with wires
your best bet would probably be an apexi safc. are you sure its running rich. and not lean?cool thanks also i've noticed the motor is running a little rich i know its probably because it may not have got a ecu tune when it was swapped but i dont have the money to do a ecu tune so is there anything else i can do to make it run leaner atleast for small amount of time so i can get it to pass emissions by the way it is a blacktop sr20
