hi guys. good day. lately, i've been experimenting with my 93 sentra ga16de engine because of problems. i felt that the car was running lean so i decided to turn the screw on the mass air flow sensor. hmmm... i think that wasn't a good idea. i have a problem now. i can't exactly remember the voltage reading on the maf sensor pin D. pin A i believe is the pin going to the ecm that change value when the throttle opens up. i know that the voltage range for PIN A is 0.7 to 1V when idling (wrt to batt gnd). i want to ask for your help cause i need the voltage reading (wrt to batt gnd) of PIN D of your maf sensor. pls. i need some input/readings from you guys. TIA.:newbie:
note: pin A and pin D are the pins on the edge of the harness.
