I noticed that on the air box which the filter goes in, there is a tube that goes to the the back of the headlight, i trired pullin the tube at the botom of the air box but it didnt want to come off, so hows the easiest way to remove that tube?
once you take the bolts out and pull the lower box off there'll be a small tube going under the finder behind the bumper. just pull it'll come apart. however u gotta pull the bumper to get the lower box off (if ur planning to run a CAI)
well, you don't really have to pull the bumper cover out, just the wheel well cover from lh/frt corner. the resonator box is pretty big and dampens intake noises in stock form.
i had an idea of just opening that up as to provide cooler air into the filter box (on top) and leaving the snorkel pipe (the one behind the headlight) on as well. the resonator box only has a small hole for water to drain off. i just went ahead and did a CAI and enlarged the opening to allow the piping to go through.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
