throttle position sensor harness connector... does anyone have a picture of this particular piece of hardware in the engine bay. it needs to be diconnected in order to advance the timing. for those of you who've done advanced timining, is this an easy piece to disconnect/find? the rest of the directions are fairly straightforward. i just want to doublecheck that i'm doing everything correctly. any pics or input would be greatly appreciated.
by the way, for those of you living in so-cal (where 92 is hard to find), how much have you advanced your timing? if you're running at 15 degrees, notice any problems with 91 octane? in other words, can i advance 15 degrees and safely run on 91 octane?
