DOT 3 brake fluid is used.
The ABS warning light is telling you that your truck's rear ABS system is not working properly. The input is taken from the ABS sensor at the rear diff, near the front pinion seal. Usually the wires to it get damaged or the sensor fails. When the lamp is on, your ABS system is disabled.
