I just purchased my 95 s14, and the abs light is always on, it doesnt flash or anything. My braking power is also very limited if i do not pump the brakes... I checked the fuse by the driver kickpanel, and its not blown. any idea on whats going on?
If the braking efficiency is low, check these:
- low on brake fluid
- air in the brake system
- worn out brake pads
If the ABS warning light is always on, it indicates that the ABS control unit has detected a problem. You need to access an FSM for your car which contains a diagnostic procedure for determining what fault code is set. The fault code will tell you what component is bad.
