Hey everyone im new here, just got a 1992 Nissan Maxima Overall in good shape only trouble is some wiring inside the dashboard is disconnected. Dash Lights do not work along with speedometer and mileage. I need to figure the easiest way to take apart dash to repair. Any help would be greatly appreciated.
My experience on removing dash boards, done two in domestic vehicles, is there is a few plastic parts that invariably get broken. So be careful and if it seems like something is holding it back, take a good look before going for the screwdriver to pry off. I would think you need to remove the upper dashboard section that goes up to the windshield and the heater/AC instrument covering first. Then tackle the other sub assemblies and their fasteners, usually pan head sheet metal screws, phillips #2 called into action. You will probably take off two or three sub assemblies to get to the actual instrument panel. You could check your local library for a repair manual for your particular model and see if there is an exploded view diagram of the dash assembly in that repair guide. Best of luck.
