Hi all, I have a b14 sentra, with a/c problem.
Things checked, freon pressure, condenson, all fuses, everything is ok.
When i put the a/c on, it blows air, but not cold air.
From one day to another Igot my self in this problem.
Also on thing, the dryer doesn't get power, no eclectric power there.
Does someone know what is the problem?
2018 Nissan Pathfinder SL
check to see if the compressor clutch is engaged and turning the compressor.
The center of the compressor pulley should be locked to the outer.
Are you looking at the dual pressure switch ?
This connects the power to the ECM so no 12v at terminal two is bad. blue/yellow
HA-36 in the FSM, download one for free if you don't have it from phatg20.net
