Rear drivers side door will not open. Outside latch appears not to be attached internally, swings freely. Inside latch has some tension but does not feel like the same tension/tension points as the passenger side rear door. If I can't open the door I can't remove the inside body panel to trouble shoot. I have removed the panel screws. Can't get to the edges of the panel to pry open with the door closed. Tips on getting the door open are welcome.
Moderator
Damn, that sucks...the little plastic linkage clips inside the doors are known to pop off or break, leaving you with a shut door and no way to open it. I'd ask a Pops-A-Lock guy over the phone if there's a way to Slim-Jim a back door or something, maybe they can get some linkage diagrams and unlock it that way somehow.
Moderator
Oh, here's an idea, you can take off the opposite door's panel and inspect that for ways to get it open...
