OK well this is a two question thing. I've got a 98 Nissan Pathfinder and when i have the headlights on the left blinker continuously stays on as if it were a headlight. Is it the blinker relay?
Second. When i first start the car up ANYTIME it bogs down but always starts. then also if i turn it off after driving it(when the engine is warm) it won't start back up, like when i get gas.
Help?
i am not sure about your lights problem but your running issue sounds like a coolant temp sensor problem. When thay go bad the computer thinks that the engine is at -40 degrees F so it is sending ALOT more fuel than it needs and flooding the engine.
