The fuel tube seems to be holding the pressure which indicates no major injector leaks. If you had leaking injectors, the pressure would have dropped rapidly in a very short time.So I performed the fuel pressure test. With engine idling it was around 34 PSI. When engine off it was around 42 PSI. After turning key to off position it dropped to 39 PSI.
After 10 minutes the pressure dropped to 36 PSI. After 15 minutes 33 PSI. After 20 minutes it was around 30 PSI.
