My g/f ran her 97 altima over a curb and put a hole in the trans. pan, and after the replacement and fluid change now it will not shift into from 2nd into 3rd or 4th gear. After I did the fluid change I reset the cpu, and the check engine light has not come back on. I had the codes checked and the only code was a tcc error. The service manual says that this problem is either from a solenoid valve or control valve assembly issue. Could the issue be the tcu or is it more likely a mechanical issue. Any info on the cause of this problem is greatly appreciated.
