i got a 96 frontier 2 WD and i changed the idle air sensor, which i thought was the problems but the truck still does it, and it cut out when i stoped yesterday, so..any ideas whats wrong. it idle's at about 1000 then i put it in drive and it goes down to 500. then when im stoped its sparatic and alomost cuts out. any ideas? thanks
How about some more data?
Check engine light on? If so, have you read the code?
Air conditioning on or off? If the A/C is on does it behave the same with the A/C off?
How many miles on the truck?
How did you decide the idle air sensor was bad?
Have you recently inspected/replaced the usual suspects (e.g. air filter, plug wires, plugs, distributor cap, rotor)?
Steve
