To all concerned....
We have a 95 Pathfinder, suddenly it died and we had it towed home, after some checking, there is no gas being pumped by the fuel pump to the filter in the engine compartment. Should I hear the pump priming when the key is turned?, is there some sort of safety option that would stop the pump from operating?, is there a wiring diagram that shows the pump wiring in the electrical system that I can view?, and the fuel pump relay, is there an easy way to test to see if the pump wiring is open or good from the relay on the fender? I know there alot of questions , but this is the first time working on our Pathfinder.
Thanks in advance for any info that you can supply to help me.
Larry
Larry
