1 - 7 of 7 Posts
I hadn't driven our 95 Pathfinder at night for a very long time. The weather turned bad and my wife drove it to work. I noticed it had no tail lights or dash lights. I checked the fuses below, on the passenger side, and they are all good. I looked under the hood for another fuse (possibly), but found none. I did find 2 fuses for the headlights under the hood. They are in with relays on the passenger side on the fender.
About 6 weeks ago, I replaced the battery terminals, which were highly corroded. Maybe this has something to do with the problem. Anyone have any ideas? Is there another fuse box somewhere?
Also, I drove it last weekend and found out that the key will not unlock the rear glass window. Could this be related? The key will unlock the hatch. Thanks.
Is the fuse between the switch and the lights? I would suspect it would be. If there is no power at the fuse junction, I guess it would just about have to be the switch. Does the round end snap off somehow? It is on the blinker assembly. I jacked around with the switch last night thinking I may get it to come on, but nothing. Thanks.
1 - 7 of 7 Posts
