Hi all,
I have a 94 Sentra XE and when Im turning (usually right) there is a 'knocking' sound comming from the front passenger side. does it also when hit a bump. anyone has had similar probleme or have an idea of what the problem might be ? Thanx !
Destroyer of worlds.
bad cv joint. look at the inside of the wheel, you'll see the axel connecting to the wheel in the center. where it connects is a rubber boot. if the boot is torn or shows evidence of being torn(grease splattered all over) then the cv joint is at fault. if it hasn't been doing it for long you may be able to get away with replacing just the boot. if its been doing it for a couple weeks or more though, it would be reccomended to replace the joint/half shaft.
