1 - 8 of 8 Posts
Biru O' Kudasai
The 93 (and 94) did not have a relay for power, they used a circuit breaker in the constant power side with the power from fusible link G which is under the hood. The circuit breaker is located behind the fuse panel and is a round black can with another side by side.
Troy
Troy,
Thanks for the reply. I might not have identified the part correctly, but this is the information I got from the part.....( Amp Assy, P/WDW, 254240E00 ). It' s by Niles of Japan. This part mounts is each door to control the windows. I have searched the internet, but have not been able to find.
Boudreaux
Biru O' Kudasai
That is the power window amplifier and I thought the driver's side front window used power directly from the main switch but I'll get out my 93 wiring diagram to check...
Troy
Biru O' Kudasai
The master switch sends a data signal to the door power amplifier but each door switch goes into their respective power amp. If you can roll the window from the door switches in back then the power amp is not the problem.
Troy
Biru O' Kudasai
Try humoring me by replacing the no. 1 circuit breaker under the fuse panel. This is why I think it is failing because when it is under a big load like when rolling up the window it trips and then resets itself after a short time. The load is rather small when rolling it down. Since you replaced the main switch and the driver's side front window is directly from the main switch and has no power amp. Then since your back windows are having the same problem but do have a power amp for each one of them which power is routed directly from the breaker to the main switch and each one of the power amps. The circuit breaker is the only common link with a good main switch. The power amp is going to be a dealer item if you want to still get one.
Troy
1 - 8 of 8 Posts
