My daughter's 92 Stanza xe engine has begun rolling backqward under torque to such an extent that the ac belts loosen and squeal/ burn. I am not sure if this is a broken/ cracked engine/ transmission mount, some other bushing, or a loose or broken fastener. I changed the head/ valves, chain about a year ago, requiring lots of movement, jacking, loosening/ retightening of engine and transmission to refit the pan etc. any idea which mount this might be? I have changed the front, top driver's side mount. Is there a trick to adjusting the several belts that compensates for the torque roll?
Larry Runnels
Larry Runnels
