HEY GUYS!
I have a 92 sentra GA16DE 1.6 my driver side axel is bad need to be replaced is the smaller one of the two. can anybody tell me what's the best way to change it? it is true that in order to replace one side the other side need to be taken out too? hope not!! help please any help count!! thanks!!
they are no trouble, they big thing is removing the axel nut and popping out the axel from the hub. Nissan actually cross-threaded mine into the hub. I did everything to push this out, no hydraulic press could pop this out, no heat or anything. so I ended up replacing my hub and the axels. What a mess. Otherwise, its an easy job. All you really need to look into is to make sure the c- ring on the end stays on when you pull it out.
I hope that you replaced the axel seals while you did this. Because they will tend to leak after new units are installed. they pry out easy and you tap the new ones in. easy
Chris 92 classic
