hi everyone!!!
I have a 91 stanza that won't start. I tried changing the coil because there was no spark, but it still won't start. Can it be a relay problem? If it is can anyone please tell me where to locate it? Any help will be greatly appreciated.
digs said:
hi everyone!!!
When you changed the coil did you see spark? Also, what happened before it didn't start? Any noises or changes in performance before it died?
Yes only when I turned on the ignition. The car just died out while running on the road. Everything just shut off. After it died out i was able to get it started, but it always died a while after it starts. Now it won't start at all.
well, it could be, as was the situation in my case, that the timing chain jumped enough teeth so that it wouldn't run. Check to make sure you have fuel getting to the cylinders also.
