I'm new to the board, so my intro will be included with a couple of questions. What brings me here is searching for some expertise with those that have worked on Nissans. I've put in 11 years as a Chrysler tech, and have been out of wrenching for about 5 years now.
I have a friend that has a 1990 Stanza. The engine is a 2.4L (KA24E).
Here's the story......
She had it die on her and had a friend try to fix it. He did the tune up stuff....plugs, dist cap, rotor, & wires. Of course that didn't fix it. Well along comes me 1.5 years after. It's been sitting in her driveway since it died.
I found it had a bad fuel pump, replaced it. The car did start, but was very noisy, and smoked REEEEAAALLL bad. It also would not idle on it's on. I found the timing chain guides were worn out, one was gone(broken and in the oil pan). Compression sucked, rockers rattled, etc. So I proceeded to tell her it needed rings and such. At least a minor rebuild.
I did the rebuild....rings, bearings, chain, guides, and such. One thing I did notice, and did not replace....the lash adjusters(lifters) have some pretty badly worn spots.
Ok...all is fine, got the car to start. However, the lifters are noisy....shoulda replaced them, but at approx $20 each.....figured I'd take the risk. The smoking isn't there. But it still won't idle on it's own. Cylinders 1 & 4 miss. 2 & 3 are carrying the load. The plugs get the dry carbon on them....looks like running rich. On some of the Chryslers, this would indicate a MAP sensor. I think I've seen similar troubles from a bad EGR valve too. This does have the EGR, but no MAP sensor.
Plugs, wires, cap, rotor are good. EGR valve is probably not, but the budget is real tight, so I don't want to replace parts without knowing I need to. It does smoke a bit....but it appears to be just from a rich mixture.
Any ideas what I could look at that would cause the missing? It could even be the wear on the lifters.....but I gotta know before spending $250 on that. If any additional info is needed, ask away! Thanks for your help.
