Hey fellas I could use some help. My 89 Pathfinder won't start. Its got a new battery, starter and alternator.I had this problem before I changed all those items listed and now I'm back to square one.I turn the igniton.. nothing. What else should I look at? My next stop is taking it to the dealer.
Thanks
P.S. Pathfinder starters are a bytch to replace!!
Moderator
They're not bad if you have a body lift. ;) Go straight through the fenderwell, no prob.
Many things could be wrong. There are at least two or three relays controlling whether the engine starts or not. A couple of switches, too. Ignition switch, shifter position switch (inhibitor switch), etc.
Have you tried hooking a wire directly to the starter solenoid to see if it turns over with a direct application of power?
yeah I've tried that no luck. It's probably a relay(I hope) I'm getting it towed to adealer today. Thanks for oyur input.
