1 - 7 of 7 Posts
I once saw a 88/89 Sentra coupe(u know the less boxier model with rear hatch door) dash with speedo and rpm gauge on ebay. it's looks 100 like the one in the sentra only with a rpm gauge. does any1 know if it would work with the sedan mode with out new wiring?
Still moderating..sorta
Just buy a tach and stick it on your dash. Click on my sig, there is a picture of mine there.
I tapped a line right off the ignition coil. It doesn't look good but it works. I'm not sure how the GA16i is wired, but you could try it my way.
Go to your distributor. The one line that does not go to the engine goes to the ignition coil. You have to splice a new wire onto the green wire on the ignition coil. Atleast that is how I did it on my e16i. Your engine is different from mine.
1 - 7 of 7 Posts
